Fatal Device Hardware Error
I took my new Elements 1T portable hard drive out of the box and plugged it in. It showed up on my File Explorer. When I clicked in it, I got an error message saying that “The request failed due to a fatal hardware error.” I downloaded the recommended Windows Lifeguard Diagnostics and ran the scan test. It passed. Now what do I do?
Hello stubell,
Have you tried using the device with a different USB cable? If not, please try that.
If issue persists, contact WD support for direct assistance on this case.
http://support.wdc.com/support/case.aspx?lang=en
