External WD Elements drives on Linux systems
I have been using two WD Elements 2TB drivers with ext4 for a while, the only problem I have is that they don’t ever go into sleep mode while mounted. I haven’t been able to find a solution for this problem anywhere, so this is kinda my last hope.
Does anyone have a clue hot to make WD Elements 2TB drivers enter sleep mode on inactivity while still mounted on Linux?
Look at the drive specs Linux isn’t a suppoted OS that is probably the problem,
Joe
