I’m not sure what happened but my wd elements hard drive was making buzzing sounds and not showing up. I found out the problem for that but now it turns on and turns off. and it doesn’t show up on my laptop
Normally, the computer storage drives are quiet and steady, but in case of any physical damages or logical corruption, they can begin to make noise. There are numbers of different types of sounds for different reasons. Some types of sounds are due to software or driver issues, some of them due to hardware issues, and sometimes due to mechanical faults of the hard drive.
If there is any noise, then you can try the subsequent fixes which people have used to overcome the issue:
Check whether the hard drive is getting enough power or not. You can do it by plugging the power adapter directly into the power supply.
Replace the data cable with the new one and turn on the drive. Now, if it does not make any noise, then the data cable might be faulty.
In case the drive still makes noises, then there is a high possibility the drive is failing and needs to be replaced.
Mainly, HDD failure can happen due to the bad power supply, virus attack, damaged block, sectors and corrupted operating system. Here, I also suggest you to check out the below blog that explains all the measures to check the health of any hard disk.
Hope it will help.
