Ext Pro CF 160mb/s 32GB not visible to windows 10 Pro 64 in Nextech card reader but 16GB card is.
I had/have an Extreme Pro CF 90MB/s 16GB card that my Nextech all in 1 card reader can read fine, but my recent upgrade to an Extreme Pro CF 160mb/s 32GB/s CF card isn’t. I have had no luck finding an actual site for Nextech to get offical drivers and Windows 10 update driver says the card reader is an unknown device even though it works with the 16GB/s card. I know this is more then likely a card reader issue but I thought I might be able to get some help here.
Thanks!
