I have a 1-TB disk with password protected but forgotten the password. I tried Smartware but couldn’t find any Setting for removing security. I also tried WD Security by enter 5 wrong password and no option shows up for erase the disk.
Please assist.
I don’t know of a workaround for the issue your experiencing. Try to contact support to see what they can tell you.
https://support.wdc.com/support/case.aspx?lang=en
Thanks, just logged it.
password forget recovery password possibles
