I have an Elements 5TB drive. I have been using it on a Windows 11 Home computer for some time with no issues. Yesterday it stopped working although the lite is on. When I unplug and plug back in I get a message from Windows “USB Device not Recognized”.
I have tried the following:
- Unplugging and plugging back in the drive.
- In Device Manager stopped Root Hub from going to sleep.
- Changing to a different cable that is known to work.
- Plugging the drive in to a different port.
- Plugging the drive in using a hub.
- Plugging the drive in to a USB port on the back of the computer.
- Updating Windows and restarting.
- Selecting the USB device and searching for new drivers.
- Uninstalling and reinstalling through Device Manager.
The light comes on and I can feel that the drive is spinning but nothing will get the computer to recognize it, also it does not show up in drive management.
The computer it is used with is using Windows 11 Home. I plugged the drive, using the same cable in to a computer using Windows 10 Home and it worked normally. What can I do to get my Windows 11 computer to once again recognize the drive? The computer does recognize all other external devices as normal including a Seagate external drive. It also instantly recognizes anything plugged in like a tablet or phone. When the drive is plugged in it makes the initial “boing” sound but then immediately makes a second “error” sound and shows the Windows error message.
