element launch program won’t run in windows 10.
It seems that it is a system specific issue with the Auto Run Settings on windows 10 Computer.
You can try enabling and disabling Auto Run from the Settings in your computer to check whether the Auto Run Window Pops up after connecting the hard drive.
You can also press and hold the Shift key when you insert a device to open an AutoPlay notification to get the Auto Run Pop Up on your computer screen to take the convenient action with the hard drive.
