Editing VCD contents on Passport Ultra - is it possible?
I’d like to add a small folder that will pop up with the rest of the VCD contents before the drive is unlocked (i.e. with the WDUnlocker program). Is this possible?
Thanks
The VCD is a virtual CD, not sure if you will be able to modify that. At least through the WD Standards procedures that’s not possible.
