EasyStore shared between MAC and PC
New to WD easystore and working on a project with someone who uses a MAC (it’s their drive). I need to pull files off it to utilize in our project, but can’t get my PC to recognize the drive. I’ve downloaded the Discovery and Utilities software, but still no go. Suggestions please? It’s driving me crazy! Thanks.
Hi Sue_Arizona,
MacOS supports HFS+ file format which is not supported by Windows OS. It is recommended to use exFAT file format which has R/W access on both Windows as well as on macOS.
Get HFS+ filesystem support for Window. HFS+ for Windows by paragon software| Paragon Software
There should be free software some on there internet. Like Brandon states, format the drive as NTFS or Exfat. I think WD let consumer download a free Paragon software for Mac that allow to format the drive is NTFS.
https://support.wdc.com/knowledgebase/answer.aspx?ID=20717
The issue is formatting compatibility. Because it’s a Mac drive, it is likely formatted in APFS or HFS+, which Windows cannot natively read. Do not format or initialize the WD hard drive if Windows prompts you to. This will erase all files.
Now you need a third-party driver to help Windows read Mac files. Once installed, the drive will pop up normally in File Explorer.
Alternatively, if you have access to their Mac, have them upload the project files to a cloud service (Google Drive/Dropbox) or copy them to a secondary USB flash drive formatted to exFAT (which works on both Windows and Mac OS).
If you will be passing this drive back and forth, back up the data and use the Mac’s Disk Utility to erase and reformat the drive to exFAT. This will allow it to work seamlessly on both Windows and Mac without extra software. (Related blog - How to Use a Mac-Formatted HFS+/APFS Hard Drive on Windows)
