I can’t figure out how to see what I have saved on my hardrive. I would like to see and delete certain pictures that I’ve saved, but I don’t see anything that will retrieve the files. Please help!
Hi terkom61,
You can view all backed up files in backup folder created in drive folder after taking backup. If you’ve used WD software for backup, you may refer below KBA to view backed up files.
https://support.wdc.com/knowledgebase/answer.aspx?ID=15143
