I have a Nokia 1320, i have bought a sandisk ultra microsdhc 32 GB. in the case it is said that a need to download.
IS it true?
Where can i download it? I see no app in the shop.
thanks
IS it true?
thanks
Hi Abcdef,
Dear member of SanDisk Community, welcome.
[ in the case it is said that a need to download. ]
Mmm … It says on the package of the microSDHC 32 GB? Original or added?
For a card, no need to download anything.
Luck, and then you tell us, what happened, please.
Regards, Alfred. (Google translated)
Most probably you are talking about the memory zone app that is stating on the mobile version of the card.
this app you can easily download from the google app store for android.
in the case of nokia with windows os i dont know if there is a windows version for the app
Good luck.
