Good afternoon, i want to ask, does this case fit to WD My Passport??
to this External WD :
Nope, you can check the list of compatible HDD on the WD store.
Compatible models include: WDBACYxxxx, WDBAAAxxxx, WDBABDxxxx, WDBACXxxxx, WDBABMxxxx, WDBGYSxxxx, WDBAACxxxx, WDBAABxxxx, WDBABWxxxx
I was a fool and didn’t check this before I bought them both. Alucardx23, I have found that you’re correct and the drive is too thick for the case. Can you recommend a suitable alternative case?
For anyone else who is wondering, this case does not fit My Studio drives, or any My Passport 2TB drives. Nor does it have a holding space for the cable.
http://www.wdc.com/wdproducts/library/AAG/ENG/a4/4178-705180.pdf
YES, it FITS.
I have tried two methods, both of them work:
This was the way I did at first because I haven`t understood the pictures in the manual.
Then after a while I just figured it out, leading to option 2! :)
Ps.: of course you can reuse the same rubber protectors stuck on the piece of plastic. Just remove then carefully and re-stick them. ![]()
This case costs £20 (very expensive) & is suitable for WD My Passport Studio portable drive:
My Passport Studio (WDBALGxxxx)
click on above link to prove
