I purchased a WD 500gb My Book External Harddrive approximately 2 years ago. It worked perfectly for about a year, then it started making a loud whinning noise. This noise was not constant, and would go away as fast as it started. The drive still worked fine, with the noise, on my Dell Desktop PC with Windows XP… I recently purchased a HP Desktop and Laptop, running Windows 7. I installed the drive on the desktop… The WD Harddrive worked for about 3 months then it stopped… Windows 7 could not recognize this drive… It would disappear and appear by itself… I tried it on both of my computers running Windows 7, and had the same problem…
I was very nervous because I had some important data saved on this drive. So, I re-installed it on my Dell running XP and it’s working fine…( except for the occassional noise) I’m in the process now of transfering my data to discs. I’m now in the market for another external harddrive, and you can bet it won’t be Western Digital.
Western Digital’s HDDs “DOES NOT WORK PROPERLY WITH WINDOWS 7 or VISTA” Do not waste your money… If you are able, return it and buy another brand… You’ll be glad you did! In addition, their customer service is worthless.
