Is it possible to disable the FM Radio on the M260?
Thanks
Thanks
the european firmware doesn’t have FM. i dont know if its possible to load it to the Americas player. why do you want to do it?
It’s not possible to disable the FM radio.
Why would you want to? I have the m250 and the FM radio is way better than any radio I’ve had in a portable. My first was a Sony Walkman FM only that used 3 AA’s that I bought about 1980 for over $100, and I have had quite a few others including iRiver CD players and the H1xx series player/recorders that support FM. The m250’s tuner is much more sensitive than any of the others. And, it was by far the cheapest!
Message Edited by Muse on 05-21-2008 06:58 PM
