I want to know the difference between "WD Elements Portable 2TB USB 3.0 " and “WD My Passport Ultra 2TB USB 3.0 .”
About rpm, they are both 5400 rpm or 7200 rpm?
If it is not possible to know the rpm, which of the two is more likely to find a 7200 rpm? or is it impossible to find a 7200 rpm on a portable external HD? thanks in advance.
[Mod: Moved post]
