Planned to replace my ext Hdd…but 1 thing I’m confusing…
Can anyone tell me what is the difference between 1TB of My Passport & My Passport Essential SE?
I check on Web, both support USB2.0+3.0, both have capacity of 1TB…Both spec seem same…aren’t?
Only the design are different…
Anyone? Hope can get the answer here…Thanks:smiley:
They only seem to be different badge of drives
but specs are the same…
You can contact WD if you want more info
