How do I change the default date that is used when importing new files onto hard drive? It’s stuck on the wrong date.
Access the device’s web dashboard from a browser and it should set the date/time from the browser.
Does the My Passport Wireless Pro (MPWP) (v1.04.17) have a built in clock? Can it do NTP?
So, if my MPWP is in my backpack and switched off, I switch it on to copy an SD Card or USB Stick - which timestamps will be on the files just copied?
