Dashboard test
What is the algorithm of the extended Dashboard test. Is it possible to run an extended test on a windows system disk? Will the data be corrupted? Or is it better to remove the disk and use the second number for the test?
Hi @Andrey444
Have you opened a Support Case? If not opened, for more information, please contact the WD Technical Support team for the best assistance and troubleshooting:
There is no support in Russia
Were you able to do it?
