OK, so looking at the Clip+ I’ve fallen in love…with the exception of the limited capacity. So I had a pretty crazy idea…
Would it be possible to use something like this: http://www.pccard.co.uk/adapter/mobidapter.php and attached it to this cable: http://www.jqsabers.com/new-micro-sd-card-extension-cable/
Then take a 160GB (or other large number) USB stick and connect it to it formatted as FAT32 like so: http://www.online-tech-tips.com/computer-tips/formatting-external-hard-drive-to-fat-32/
Then use Rockbox (to get past the file and size limits)…do y’all think that’s at all feasible?
EDIT: I found a good cheap MicroSD extension cable!!
all I can say is -----try it—sounds like a good plan to me.—
I don’t know whether your idea will work or not, but Rockbox, as good as it is still has database limitations. The Clip+'s limit is +/-8,000. Rockbox’s is 10,000.
Is there any way at all to bypass the Rockbox file limit? Whether there is or not could you give me some more info on it? Thanks!
EDIT: After doing a little bit of digging around…I found this: http://download.rockbox.org/daily/manual/rockbox-ipodnano1g/rockbox-buildch8.html#x11-1420008.5.3
And this: (talking about the D2 but I think it’s the same idea)
Q. Will Rockbox have any limit for amount of files on the internal/external memory like Cowon’s firmware has?
A. There’s no limit for folder-based browsing. If you use browse for files by ID3 tag (using the Database function) there may be a file limit imposed by the database.
It sounds to me like the only limit is in either A. The number of files within 1 directory or B. The number of files allowed in a database. So if I used the file browser, and put each artist in a seperate folder, the limit would then be 10,000 ARTISTS right? (Since they would all be under the main Music folder.)
Is that correct or am I missing something?
There is no database limit in rockbox, although somewhere around 100,000 files I think the load db to ram option will stop working since the Clip+ doesn’t have all that much RAM. Edit: you’re probably thinking of the maximum files per folder setting. Theres no limit on how many folders you can have though.
Would it be possible to use something like this: http://www.pccard.co.uk/adapter/mobidapter.php (I would prefer it in a cable form since this looks like it might be flimsy to leave in all the time, but I don’t know if there’s something like that…) EDIT: I found this: http://www.ecvv.com/product/3493773.html If i could hook that into the clip+ and the mobidapter, then attach the mobidapter to the back of the clip+ somehow…
Another excellent reason to use Rockbox…to eliminate that annoying database refresh.
