would you maybe need the LIVE model have that work??? Had one for a short period of time and connected through the ethernet port, hooked up no worries, just didn’t suit what I need from it, don’t know enough about the routers though if the USB on the router is an innie or an outie, I did skim over a post SOMEWHERE in the last couple of days or maybe it was on a manufacturer’s spec page that had something about setting it up that way. Good luck.
Since been advised by WD that the 3TB is not suitable for working on a network…seems as though i should have gone for the 2TB version…that’s what happens when you trust the guys in the store and don’t do the homework.
