Computer won't reboot or come out of sleep mode
i have to disconnect my external drive (my book essential) before i re-boot my computer or it will not reboot. this also happens sometimes when my computer is in sleep mode- it will not wake up unless i shut the computer down abruptly then disconnect my external drive. is there a alternative solution besides shutting down computer and/or disconnecting hard drive ? it did not do this all the time it just started when i bought a new computer- i went from a gateway to a lenovo
Hi, I would check the BIOS settings and make sure that the first boot option is the internal drive of the computer instead of a USB device and see if this helps.
I’ll try that tomorrow, thanks.
Sent on a Boost Samsung Galaxy S® III
-------- Original message --------
Date:04/16/2016 2:14 PM (GMT-05:00)
To: [Deleted]
Subject: [WD Community] [WD External Drives/External Drives for PC] Computer won't reboot or come out of sleep mode
lluna April 16 Hi, I would check the BIOS settings and make sure that the first boot option is the internal drive of the computer instead of a USB device and see if this helps.
Visit Topic or reply to this email to respond
To stop receiving notifications for this particular topic, click here. To unsubscribe from these emails, change your user preferences
