I know MPW supports natively only SD cards. Which is a pity because this solution could be ideal for all photographers and the large, pro & semi-pro, DSLRs use Compact Flash as the main storage (SD’s are only backup).
While waiting (hopefully) for WD to create a CF version of MPW, did somebody find a way to use it with CF cards.
I doubt card reader would work and I could not find a CF-to-SD adapter (to use the SD slot for CF cards)
thank you for your feedback
best
andre
