First I created Rescue Media Builder on a flash drive.
WD Blue 1TB to SanDisk SSD Plus 2TB. Tried 4 times to clone drive using Acronis True Image WD Edition, manual copy and created 2Tb partition. Everything moved and NUC booted Win 10. Issues; Win 10 update loads, fails to install after 100%. Quickbook fails to open.
I decided to try the DiskJockey cloning duplicator. I will see what happens in two hours.
Cloning worked everything is back up and running except Win 10 update. Getting a few error messages from Win10. I need to expand the partition to use the entire drive. Anyone know which program to use and how to do it?
