@koto wrote:
5,72 GB …21,7 GB …Total Scanning Time both: 5.44 Minutes
That may be the crucial point: Both of my cards are 100% loaded, while yours are only ~77%/~71%.
The Time not improve by 2 with 12-13 Gig more. This can be a Class issue for SD-Card. Faster are better. ![]()
Your Filled the Player over?
Have you have leave Space for the Datanbase?
Possible. (Actually the usual time is rather 12 than 15 minutes with my Zip.)
Have you have left Space for the Database?
Yes, exactly enough. The player usually protests if it’s disregarded.
The internal card reader in these players is only about the equivalent of Class 4. Using a Class 10 will make no difference.
Time to Sandisk to improve that.
Scanning the MP3 Tags with Winamp from the Player takes 30-60 Seconds. Sandisk scnn the MP3 over the Internet or mars?
Sorry 10-15 Minutes are very bad. My pocket calculator have more Power. ![]()
@jazz wrote:
I re-tagged all MP3s to v2.3 ISO-8859-1 by means of MP3Tag – to no avail: The player is still slow, with more than 20 minutes for refreshing and 5 seconds for skipping in shuffle mode (exept for tracks on the internal memory, with which reaction time is normal, i.e. <1 s) – and this with further reduced SDXC card charge, now only 29.5 GB.
When you retagged the MP3s, did you do it on the files that are already on the card? If so, I’ve read that it works better if you change the tags while the songs are your computer and then reload them onto the card. Though I’m not sure if there’ll be any improvements on an SDXC card that’s been formatted to FAT32.
Yes, on the card.
@miikerman wrote:
Unfortunately, refreshes can take considerable time, depending on the content size. With close to 30GB of content, my player will take 20 minutes to refresh (and it’s longer on the Clip+). It indeed is time for SanDisk to re-work this (and has been, for awhile . . .).
Of course in about 10 minutes total you could resolve the issue on both your Zip and your Clip+. :wink:
I think I know what you mean… ![]()
Can i use a 128GB SDXC using rockbox?
Seeing how a 128GB Micro SDXC card has not been released yet by any company, I’d say the answer is no.
Unless you want to jerry-rig a micro adaptor and use a full-size SDXC card. Kinda defeats the portability factor, but yes, I think then it would probably work if . . . the card is re-formatted to FAT32. That’s what it takes to use the current largest capacity 64GB SDXC card.
Oh sorry, i confused the SD.
Can i use a 64gb then? (Like this one http://www.amazon.com/SanDisk-microSDXC-Memory-Adapter-SDSDQUA-064G-U46A/dp/B007WTAJTO/ref=sr_1_1?ie=UTF8&qid=1350583720&sr=8-1&keywords=microsd+64 )
I have a Clip Zip (v01.01.20A) and am having an issue with a 64GB SanDisk card (http://www.amazon.com/gp/product/B005V7WIA2/ref=wms_ohs_product
No matter how I format it, it won’t read in the Clip Zip (Settings->Info->SD Card = 0MB, Free=0MB). I have tried NTFS (which I figured wouldn’t work), EXFat (which I also figured wouldn’t work), FAT32 (used Easus MiniTool Partition Wizard to format the 64 GB card which was read by multiple XP pcs), and even the internal Clip Zip formatter (which either kept locking up or I just got impatient after 11+ hours of formatting that the screen still displayed “Formatting”).
My 32GB card works fine but my library is larger than than and it’s beginning to really get difficult to keep a separate “stripped down” set of MP3 files just for the Clip Zip. My goal is to have all of my portable devices (Nook Tablet, Nook HD+, Galaxy Tab 2 7, Droid 4 phone, and Clip ZIP) all usingt the same basic set of master MP3 files (yes, I use different apps for them to link to the PC) all with the same SD card (this card is working in the other 4 devices, just not in my Clip Zip).
Whew. Sorry for all the info, but I wanted to be as complete as possible on the first post. Thanks for any help.
It will need to be re-formatted to FAT32, but not all formatting software may do the job in a way that your Zip may like. Have you tried the SD Associaton’s Formatting Tool?
Here’s another formatting tool that I hear people have have good results with in doing exactly what you are trying to do, re-format a 64GB SDXC (exFAT) to a SDHC format (FAT32).
Please let us know if either of these work for you, as there will be others who will undoubtedly want to do the same. ![]()
I believe putting the card into the Android phone will take care of it. Initially it will send an error message of some sort and ask if you want to re-format…say yes to that, and the phone should take care of the formatting for you.
Thanks for the advice - much appreciated. Before actually checking out the links you provided, your post got me thinking.
What I believe was the problem (not sure, but once I did the following, it worked), when I used the Easus partitioning & formatting tool, the 64gb sdcard showed up with two partitions - a 16mb (first partition) and the rest as the 2nd partition. This kept happening no matter what tool I used to format the drive (including the one at sdcard.org). I couldn’t enlarge the 2nd partition to “gobble up” the first (so as to have 1 partition), but finally realized (duh) that by deleting the larger 2nd partition, I could enlarge the 1st 16mb partition to consume the entire drive. Once I did this, then formatted FAT32, the sdcard was immediately recognized in my Clip Zip.
So basically, I used a USB writer for SD Cards (including SDXC) to format the card using the Easus tool, AFTER I deleted the 2nd partition and enlarged the 1st partition. Something so simple.
Thanks for your help. Now I have to see if the 6000 file limit I keep seeing is truly the limit with this revision as a reason for the 64gb (instead of existing 32gb) card is due to the number of files I have.
BTW - I just read the post about putting the card in an Android phone. I did try that before my initial post (since just the other day I put in a new 64GB card into my Droid 4, I tried the 64GB card I was planning on using in my Clip Zip). It still wasn’t recognized in the Clip Zip.
I have close to 40 different combinations of sequence, operations, applications, etc. that I tried before my initial post (been a network & pc tech for many years, but just kept drawing a blank when it came to this simple thing that I was unfamiliar with).
Again, thanks for the help everyone.
Glad you got it going and it’s working for you. The ‘official’ database limit is 8,000 but it depends a lot of many variables. A lot of people we hear from actually encounter this limitation at around 5,000 in the real world.
Of course, if you use Rockbox firmware, there is no such limitation. ![]()
I was thinking about using Rockbox based on some things I’ve read from other users, but the Rockbox site states “Rockbox runs on these players, but is incomplete, less usable or has problems that limit it to advanced users”.
I have no problem with incomplete or less usable, but does it have problems that limit it to advanced uers? I just want a simple device with a simple app (at least for what my Clip Zip is used for).
Regarding real world usage, do people feel Rockbox on the Clip Zip is reliable and I shouldn’t have problems with it (forcing me to become an “advanced” user)?
Thanks for any pros/cons or advice.
If you click on the Zip link on the front page it has a description of whats incomplete. At present, its just the sudoku plugin that hasn’t been fixed for the Zip’s screen size. I’ll probably make the zip stable shortly.
