Hello I am having a problem of unable to mount drive on to Mac OR Windows PC. I kept getting error can’t read the drive. Here is the error I get for Mac
If I try to open with windows it asks me to format it but I don’t want to do that. There are some important data that I need recover. Is there any way to get those file without formatting drive?
Have you opened a Support Case? If not opened, for more information, please contact the WD Technical Support team for the best assistance and troubleshooting: https://support-en.wd.com/app/ask
When you connect an external hard drive on Mac, it will show up on Desktop, Finder, and Disk Utility. But sometimes the external drive won’t appear on any of these places. To fix the issue, you can try the below methods:
Change MacOS settings
Reset Mac firmware settings
Fix external hard drive connectivity issue
Troubleshoot external hard drive
Recover data from non-mounting external mac hard drive using reliable data recovery software
Further, I suggest you to check the below link for detailed steps to be followed in each method above.
