Can't backup
It backed up the first time. Then, it hasn’t. I have tried “backup now” to know avail. I would like to change the schedule to see if that will work, but can’t figure out how to change the schedule.
Hi jsoldano,
Maybe you should try contacting WD’s Technical Support about this.
https://support.wdc.com/support/case.aspx?lang=en
The link below will allow you to call support.
