I am pulling a WD Sync file from WD MyCloud app access on my tablet. I cannot find a way to save the file so it is synced. It is currently saving to internal device storage within the WD app files. So, when viewing on another device, the file is not updated. Then when I open the file from the WD MyCloud app on the tablet again, it still pulls the internally stored file. Can you tell me a way to allow opening of the file, being able to work with it, and it being saved so that it may be automatically synced with my other devices? I am viewing the file in Excel for Android on the tablet.
Hi, with the My Cloud Mobile App, in order to be able to modify a file and have it updated on the My Cloud, you will have to save it on electronic device first. The My Cloud Mobile app does not have the function that you are looking for unfortunately. If you have any other questions regarding the application, you can take a look at the link listed below.
