Can not access files - help please!
Hi all,
I have a WD My Passport Ultra and i use it on a Toshiba laptop running Windows 8.
I think i may have induced a critical failure of some sorts on the passport as it no longers shows any files.
It connects with a permanent light on and instead of displaying the contents all i get is a Local Disk (f) icon and that the device is not ready.
Any ideas?
Lottie x
Welcome to the Community.
If the hard drive is at least detected as a local volume then the issue could be related to the file system and a data recovery application should be able to repair or extract the files. I have seen Community posts recommending TestDisk and PhotoRec.
Regards,
