Can i access contents from MyPassport Wireless while it is connected to another device
I have connected My Passport Wireless to a laptop using USB and i wanted to access its contents through wi-fi from another laptop. But the moment i connect MyPassport to any device the wi-fi gets disabled.
Is it possible to access its contents dynamically while it is connected to another device via USB.
Also will any WD device supports this feature?
Thanks
No. It’s not supported and doubtful it could be. When attached via USB, the PC is the master of the disk.
When using WiFi, the MPW’s internal OS is the master.
A disk can’t serve two masters.
No.
