I purchased several USB 3.0 flash drives to transfer CD’s for listening in the car. My intent is to burn in ‘lossless’ format and to be able to catalogue/select by artist/title/song. While I’ve had some initial success, the cataloguing that shows up is inconsistent. Any help is appreciated. Thanks.
Have you checked if your car’s audio system supports the lossless format you’re using?
Some systems only recognize MP3 or WAV. Also, are the metadata tags properly embedded in your files?
Maybe a tag editor could help organize them better?
Thanks for the quick reply. These are great suggestions. I’ll try these and let you know. Again, thanks for your help.
