There may be a simple answer to this question, but can you backup FROM the WD external drive TO the local drive on your computer i.e. the reverse way you would normally use it. I need to save and work directly from the WD as I am running Pro Tools, so I’d like to be able to backup from it to the Mac drive.
Thanks for your reponses in advance.
Jack.
