I originally had a PC and one WDMyBook for backup - and all was working fine. I had to add another WDMyBook external drive to create capacity - and moved all of my iTunes files to that external drive. I am now trying to back up my PC and the files on the external media drive to the external backup drive - but when I go into the WD SmartWare I am not seeing an option to select / configure the backup to include the external media drive in the backup? I am operating the backup in “category” mode. Running a PC, Windows VISTA-64
Smartware only supports internal drive or another non smartware external drive…
Thanks. The folks at WD Support said that I could flip into file backup mode and the drive would appear - and that is not the case - only the nonWD drive appeared. It appears that you know more about their product than they do! Can you recommend any good backup software that I can use to run my backups?
