WDBAAF0010HBK
I have an WD My Book Essential 1Tb. and i opened the case and take the WD 1Tb Green from it and use it for internal drive
( the data on it can’t be read on computer running Win XP … it says RAW… i have to re partitioned the hard drive, before i re-partitioned the hard drive i try to read the hard drive on the usb via my WD My Book Essential and all the data is there… so i think the WD My Book Essential have a different partition tipe or so… :pt1cable: )
the problem is when i try to replace the original Hard drive that how to make my old 640Gb or 750Gb WD Green can be read from my WD My Book Essential case ?
it look likes the drive doesn’t work on it… even i try to put the 1Tb back into the case… its wont work ![]()
So anyone please do u have any idea what to do, its sure the WD My Book Essential is out of warranty
