I am a former iPod nano owner that switched to Sansa Fuze because of its 8gb capacity and FM radio. I also switched because I was tired of some of the deficiencies with iTunes.
Now I am using MediaMonkey. The file transfer is much slower but I can adjust my expectations (I use MTP because I have not been able to get the autoplaylists to work right in MSC mode). Because some of my autoplaylists adjust depending a new music added to the database, and I try to load as many songs as possible, I have twice overloaded the Sansa Fuze with too many songs and this makes the unit stop working. I had to reformat, reinstall and reload all my music and playlists. With my old iPod, it was not possible to overload the unit.
Why can’t Sansa do a better job protecting the minimum space needed for the firmware to work?
I understand that it’s a little annoying, but it shouldn’t be a big problem, in MediaMonkey you should set it to leave around 50MBs of free space on the device. The transfer is slower because you’re in MTP mode. MTP mode gets a slower transfer with a fast database refresh at the end. MSC transfers quicker with a longer refresh. If you need more room, get a microSD card.
Message Edited by gabe565 on 10-09-2008 05:19 PM
I had a similar problem with an external micro-SD filling up part-way thru an AVI file (using the Media Converter). It simply locked up. After moving some music files from the external to internal, and completing the conversion, I began having all sorts of problems…under artists->album all tracks appeared twice, though all looked fine when hooked up to the PC. I even deleted some folders, yet they continued to appear after “Media Refreshed”. I had at least 4 phantom music folders which were nowhere to be found in any folder on either internal or external memory. Even after manually deletingevery music file (leaving only the 10 pre-loaded photos) it said there was only 1.13GB left, even though the folders remaining were less than 1MB in size.
I ended up removing the external memory, and reformatting (via the Settings menu). I tried copying the preloaded music off before formatting, but every one was corrupt.
Is there any place I can download and reload the songs it came with? (e.g. “Alias & Ehren”, “Andrew Paul Woodworth”, thru “Umphrey’s McGee”)? Every pre-loaded MP3 file, remained the same size, but when played (on two computers), every one was the same 6-seccond loop (a fade out from another MP3). Something like “AutoM3U” or a download link for registered serial numbers?
Dave
4GB Sansa Fuze
Firmware: 01.01.15
Message Edited by CoindoorDave on 12-09-2008 04:28 PM
