Hey guys,
I just bought a 8Gig SanDisk microSDHC card.My question is,do i need to format it before using for the first time?And how do i do that?When formatting under FAT or FAT32?
Thanks,
SR
Hey guys,
Thanks,
SR
A new card shouldn’t be formatted. The only time a card should be formatted is if it is not functioning properly.
If a card must be formatted, use the command
Format [driveletter]: /FS:FAT32 /A:32K
to format it in FAT 32 with 32K clusters.
Yeah, I had mine for 11 months and never formatted it. I erased it every couple months when I formatted the Fuze, but never formatted the card…it always worked fine.
SD memory cards . . . truly a plug’n’play device.
No muss; no fuss.
Thanks guys for your helpful replies.People in this forum could not get any better.
Thanks,
SR
