album ART
HI MY SANDISK CLIP SPORT GO IS NOT SHOWING ALBUM ART I ALSO TRYED ON MY CLIP SPORT PLUS AND ALSO HAVING THE SAME PROBLEM I TRYED ALOT OF TIMES AND NOTHING
BUT MY SANDISK CLIP SPORT SHOWS IT PLEASE HELP
Are you describing these two problems using the same mp3 audio file that properly displays its embedded art on your Clip Sport?
Yes I’m having the same problem with them
From a little bit of research into album artwork, it appears there are a number of formats for storing/attaching album artwork and information to music files. SanDisk appears to only allow one format and it seems to be an older format. They really need a firmware update to fix this (and their Shuffle problem) and the fix should be to recognize numerous artwork formats.
Which ID3 tag does it need to be?
