Hello.
I would like to ask you something.
I have: Windows XP SP3 32x
and I just bought a 4TB HDD.
I’ve read on the declaration that is formatted as NTFS
and that it will work with Windows XP 32x ‘right out of the box’
And so, I plugged it into my PC and it works just like it’s stated.
But then, I noticed a one thing, that really worries me…
Although the disk is completely empty, under the disk properites is shown that 4.85GB is used.
I checked the disk, just in case, with an option ‘Hide protected operating system files’ turned off
and there is only a ‘System Volume Information’ which counts as 0 (zero).
So, I started to copy some data on the disk, to see what will happen,
and every time the data would be copied, it showed a random size of occupied disk space…
Please, can anyone maybe advise me about this?
I really don’t know what shall I do now…
