3tB HELP!
Had the hard drive working fine before reformat , but after reformat doesnt wanna work properly
Windows 7 -I7-16 gig ram. One hard drive in PC 250 G SSD ,
one external usb drive 3TB wd green
i plug in hard drive , doens’t load , go into device manager disk drives! its there , gotta right click and then hit populate , then it will show up on my computer after a while of loading!
Once it loads up opening the file takes long time, playing a movie from it lags it , going to anywhere in that hard drive takes while , maybe 30 seconds to open a simple folder , green bar just scrolls.
If i don’t hit populate it won’t show up at all in disk management nor my computer.
What am i missing ?
I already went to properties clicked on usb and took off power saving setting for max power .
yourboycal,
Such performance issues may indicate an issue with the device, or incorrect formatting parameters. I would recommend performing a complete drive test using Western Digital LifeGuard Diagnostics for Windows to confirm SMART status and a sector scan. If the unit is to pass the tests, then a complete low-level clean (Write zeros) would be the next step in order to initialize the disk as GPT as opposed to legacy MBR.
Additional information can be obtained from the following links:
http://wdc.custhelp.com/app/answers/detail/a_id/940/
http://wdc.custhelp.com/app/answers/detail/a_id/1211/
