I’ve had this 3tb (model #WDBACW0030HBK-01) since August (didn’t install the smartware) and it was working fine until last Saturday, It no longer shows up in My Computer. It does show as Unknown and Not Initialized in Computer Management, if I try to Initialize the disk i receive an error message of “The request could not be performed because of an I/O device error.”
I’ve performed many different troubleshooting methods, swapping ports (reinstalling the drive and drivers, usb 3.0 etc.) it usually has the light on the front fast blinking but sometimes it’s a slow blink. I’ve also tried many suggestions in this forum, most partition managers do not see the drive, (Partition Find and Mount shows it as “WD My Book 1140 USB Device” with a size of 0kb and no partitions. It also shows in the safely remove hardware and Devices and Printers and as My Book 1140.
Device Manager shows WD My Book 1140 USB Device/Properties/ Volumes show:
Disk: Disk 2
Type: Unknown
Status: Not Initialized
All sizes are reported as 0MB
I recently installed Smartware onto my main (not wd) harddrive, if I hover the mouse over the taskbar icon I see “My Book Essential USB HDD, 0% used” but if I go into the Smartware program the drive isn’t listed. I have the SES driver installed.
Data Lifeguard results:
Test Option: QUICK TEST
Model Number: WD My Book 1140
Unit Serial Number: WDC-ROM SN# XYZ-
Firmware Number: 1003
Capacity: 0.00 GB
SMART Status: Not Available
Test Result: PASS
Test Time: 15:30:36, October 27, 2011
Test Option: EXTENDED TEST
Capacity: 0.00 GB
Test Result: PASS
Test Time: 15:30:42, October 27, 2011
Test Option: WRITE ZEROS
Capacity: 0.00 GB
Test Result: COMPLETE
Test Time: 15:31:03, October 27, 2011
Note the serial number XYZ-, I doubt that’s right.
Also tried installing Ubuntu and it never found the drive anywhere, drive does show up in my BIOS.
Easus Partition Manager doesn’t show the drive, neither does Test Disk.
HD Scan for Windows shows it as WD My Book 1140 -11 (Firmware 1003, serial 11)
I don’t want to lose the data on the disk but I’ve been unable to find anything that will format the thang, also read that I’m now unable to remove the drive and put it in a new enclosure due to encryption, this hd was a replacement for a failed WD drive.
Kindly reply if you have any ideas…
