Turn it over.
@digvijay8104 is it showing on your system or not? Can you give more information about this
If your 32 GB OTG drive isn’t working, please check that it’s plugged in properly and that your device supports OTG. You can also try connecting it to another device or port, and ensure that it’s formatted correctly. Update your device’s software, and if it still doesn’t work, the drive might be faulty and need to be replaced.
