2TB WD red for My Book RAID compatibility
My “My Book Duo” turned its drive #2 LED red today. The manual says, I need to replace that HDD with an “exact” same model. The model I’ve got there is wd20efrx-68euzn0, but searching online now I only find wd20efrx with no “-…” part at all. Does that mean they all are compatible?
Thanks in advance
Hello, lyakh
Well, WD® do recommend to use WD® RED hard drive, check the given below link in order to know the compatible drive with My Book Duo.
https://www.wdc.com/products/internal-storage/wd-red.html
Check for the given link too in order to know the compatibility status.
https://support.wdc.com/knowledgebase/answer.aspx?ID=9758
Actually it worked out in an interesting way. I bought 2 WD20EFRX drives,
i.e. not a perfect match to the original WD20EFRX-68EUZN0 drives. I
thought - I’d try, if it doesn’t work, I’ll replace both. If it does work,
I’ll have a spare one for when the other one dies too. That was the only
model I could find in all online shops I tried. When the drives arrived
and I opened one of them, its model was WD20EFRX-68EUZN0. Replaced,
rebuilt, working.
