My hard drive starts the boot up stage but doesn’t start. It’s not on disk management. Windows recognizes it for a second when it starts to boot but it turns off immediately. The light is still on during all of this.
Which version of Windows are you running ?
Meu Hd WD ELEMENTS BASIC STORAGE tbm esta assim , começou depois q copiei uns arquivo do hd (WD ELEMENTS SE) da minha irmã , acho que copiou arquivo do SE junto
Não consigo formatar ele , nem usar o programa (data lifeguard diagnostic) nele .
Meu windows 7 ultimate 64b
The possible reasons for such issues are:
- Faulty SATA cable
- When Windows unable to find ATA device
- When HDD included in storage space
- When SATA driver is not installed or corrupted
- When new HDD perceived as foreign disk
Further, I suggest you to check the below link and follow the shared methods to resolve the issue: https://appuals.com/fix-new-hard-drive-not-showing-up-in-disk-management/
Hope it will help.
