1.0TB WD External HD
I want to save to an external 1.0TB WD HDD. It is in a dock connected with USB. I have the WD Smartware on both drives. I am assuming I only use it from the internal HDD. Cannot seem to get the software working. The external drive is visible in the internal drive directory. Any suggestions please.
Dennis J. Shaw
Check the Help Tab in SmartWare. You can select help areas in the Tell Me About… column.
Good luck.
Cliff
