HI, I have a 32GB Sliding Flash Drive and it seems like the Slider sticks. Sometimes I can’t slide it open and other times I can’t slide it closed. What can I use on it to help lube the slider so it’s easy to move again?
Thanks in advance!!!
Hi HomeUser,
Dear member of SanDisk Community, welcome.
Mmm… Borrow to a Lady, “cleaning cream for skin”.
But… Put very little (~ 1 mm), and see that is not grease the plug.
Luck, and then you tell us, what happened, please.
Regards, Alfred. (Google translated)
I’d suggest to check with your reseller. There might be a good chance that they can still replace this for you.
Hi HomeUser,
Thanks for the replies, Sorry I have been away from my PC for a bit. I have not tried any of the suggested yet, but will look into it soon.
