No install or setup disk necessary. It works out of the box. Just drag & drop (copy & paste) audio files from your computer to the Music folder on the player. Done. Relax & enjoy.
About as non-techie as it gets.
But here are the owner’s manuals you can read and/or download. You didn’t say which Clip model you have, but they’re all there.
It sounds like you were sent some bogus setup disc, possibly with malware. Glad you have rolled back your computer but also run a full virus scan on it.
You should also complain to Amazon about the seller.
What disk did you have and use? As noted above, no disk is needed. The only one I’ve ever heard of coming with the Clip is one that includes a Rhapsody paid music subscription service free trial (also available online) and possibly the user manual (available here as well).
It almost sounds like the disk was acting virus-like. I’d avoid that disk like the plague.
Rhapsody would not install “checkup” or malware.They have a reputation to protect.
That is an evil seller on Amazon and it is important that you notify Amazon about the seller. Maybe the Clip was cheap so they could pull the software scam.
Use System Restore to go back to a few days before you inserted the disk. And then do a virus check. If you don’t have antivirus software, get the free Avast or the trial of Kaspersky or the online scan from Trend-Micro. But you really do need antivirus software.
