unfortunatelly yes the ssd will soon have issues if you didnt alligned it correct and used the correct configurations. Please make sure to follow the steps of the kb that is posted on the sandisk site (http://kb.sandisk.com/app/answers/detail/a_id/8171/kw/windows%20xp)toto) ensure that the ssd is correctly installed with the xp system.
Also i would recommend to use a newer Os because windows xp are not even supported from Microsoft.
In that case when you followed all the steps then you can also try the following:
format the ssd with windows 7 or later to ensure that the drive was alligned correct and then install xp on it so all the blocks are written correctly to the drive.
If you already installed win xp on the drive then you can check if there is another option to allign it afterwards.
