How do I save an email attachment to the secure vault.
Also I need to save reports and or data files from a web site to the secure vault. I do not want to save them to the computer unencrypted and then drag to the vault.
Unfortunatelly there is no way to select the secure access vault to store the files at once. you will need to save the files to another location before you drag and drop them into the secure vault. if you dont want to store them to the pc you can save them into the unsecure location of the usb stick and then put them inside the vault to encrypt.
Are you using Outlook? I have verified this yet but what happens when you do a drag and drop?
