i have an older sandisk sansa clip–not the plus–i have lost the clip on the back-does anyone know where i can find either a replacement or the action jacket with belt clip? i went to best buy online & they had an action jacket with belt clip & armband but it is no longer available & have checked online–thanks
The Action Jacket for the Clip comes with an armband but no clip–the Clip’s clip fits through the Action Jacket. According to the BB website, it’s available at some stores (you can check availability at the BB website).
http://www.bestbuy.com/site/DLO±+Action+Jacket+Case+for+SanDisk+Sansa+Clip+MP3+Players±+Black/8578023.p?id=1190676635745&skuId=8578023&st=sansa clip action jacket&cp=1&lp=2
Even better, techforless.com has a couple in stock (open box, but new condition) for $4.56 + s/h – nice deal, even with the s/h.
http://www.techforless.com/cgi-bin/tech4less/DLZ26001/17?mv_pc=google_base&tts=20100101023557
Also available at buy.com and amazon.com (techforless.com has it thru amazon.com and you save on s/h by getting it that way – http://www.amazon.com/gp/offer-listing/B0013HDE3Y/ref=dp_olp_1?ie=UTF8&qid=1262358946&sr=8-1).
The clips themselves are available at the SanDisk online store. http://shop.sandisk.com/DRHM/servlet/ControllerServlet?Action=DisplayCategoryProductListPage&SiteID=sdiskus&Locale=en_US&CallingPageID=CategoryProductListPage&Env=BASE&startIndex=16&categoryID=11449200
Hope this gives you some options and helps–
