Hi GomesAM,
Friend, other ideas…
- [ …It works in my office Desktop just fine. ]
- [ …I’m using WD latest USB 3.0 portable hardware, in the laptop, (just fine). ]
- [ …My windows is update every time automatically. ]
Well,
1- In the Control Panel / Administrative Tools / Event Viewer: see if there is information on this item.
2- See also, in the Task Manager, the processes which are running, and see what are the necessary and what to delete.
Because, there are some services programs, telephones and video cameras, that cause system conflicts, by interference in USB ports, such as: Samsung Kies, HTC Sync, Sony Play Memories, Motorola, etc.
3- There might be a conflict between drive letters being used: http://kb.sandisk.com/app/answers/detail/a_id/8482
Also, with the tool (portable app, free): USB Flash DriveLetter 1.30, http://filecloud.io/vgqzcdyh
4- Maybe what happens, is that there a corrupt line in the registry/USB, that detects this UFD as “problematic”.
Then with the tool (portable app, free): USB Flash Deview 2.30, http://filecloud.io/srp2hegw
5- Also, the intensive use of USB ports, generates “USB junk” in the registry.
Then, to clean easier the “USB junk”, you can use the tool (portable app, free): USB Scrub Cleans 1.00, http://filecloud.io/aikrqsoz
Luck, and then you tell us, what happened, please.
Regards, Alfred. (Google translated)
