SanDisk Clip sport M3U playlist not working
My sanDisk Clip sport Mp3 player will not work with M3U playlists i’ve tryed and no luck with the playist.
please help.
Without any more information about how or with what software the playlist was created, it’s pretty hard to suggest or recommend a solution.
Did you populate the playlist from the files on the player, and not on your computer?
Did you place the playlist file in the same directory/folder as the song files are in? Many people mistakenly (but understandably) place the playlist file in the Playlist folder. That won’t work with .m3u playlists.
